I had already answered what the engine in the bike is in this thread
http://www.oldminibikes.com/forum/tecumseh-engines/111147-dmp-engine.html It's a "medium frame" tecumseh engine, we usually call them "big block" in the mini bike scene :laugh: actually nothing on that engine will cross with the other "small frame" engines you have except for the magneto/charging assy under the flywheel.
1st pic is really blurry but it appears to be an HS40 engine, engine on the left on your table is an H25-30-35 2.5-3.5 hp and I would say its probably a 1971-74 due to the 2nd version of the throttle control. engine on the right is an HS40 and if the shroud that came off it is the one sitting next to it its a 1968 or earlier year 1969. you should be able to get the specs and year of the tags on both engines, the H possibly has stamped number on the top of the shroud instead of a plate.
lighted flywheels for the HS40's are not uncommon, there is usually an assy listed on ebay at just about any given time, the small H engines are not as common they were only really utilized pre 1970 when the HS40 was still relatively new and not used too much yet. They don't show up as often. One thing that IS critical when converting to a lighted flywheel on both engines is that the flywheels are wider, tecumseh used flat base studs on the shrouds for the recoils on those engines for clearance instead of the little welded on nuts. You can use those shrouds but you need to test fit, usually grind down the nuts a bit and also use screw/bolts that don't protrude to do it, or some of the shrouds used rivet on recoils, so either really short rivets or reverse them and install from the inside, the recoils for the rivet units have smaller holes than the bolt on kind.
