Jackshaft bearings were bad on my vintage Trike and wore out the jack shaft. After several attempts of while trying remove on the trike. I cut the shaft in half( it was be anyways) removed everything off the driven including the spring and slide. The pulley is seized on the shaft I have applied moderate heat and some pressure in the press. It appears that everything that is being used to applies pressure is iron and strong. Trying to avoid breaking or damaging anything. Is it safe to assume I can wrench down on my 6 ton press and pop the shaft loose?
