Today: broken thread for the inlet manifold: Use to be M6, hole was around 10mm .
I used an epoxy cement, a new screw with grinded head, the manifold to guide the screw (not tighten yet)....
Dead end thread are not easy to repair without a machine shop
I actually like JB Weld for some uses, however, I cannot imagine it holding up for very long with the heat and vibration it is exposed to in that application.
Michael
Test with gas today, gears are changing well....
I will not do more tests, I am starting to rebuilt the new old frame.
I will use the engine as it is, could be a second project went I will have the registration done.
Michael
I am starting to remove all parts from the old frame...
I will keep the front fork, to be closer as the original type, easier for the registration later (I have no title)...
I will cut the original headlight support and use a new support...
I trashed the old frame . Sunny day and not to cold: starting to rebuilt the fork...
I have new needle bearings to install , after so long some part don't want to come out ...
