Heat it, center punch and I mean get it on center, drill for an easy out. Get a straight easy-out, not the spiral kind, drive it in and turn it out. If you have a welder, weld thru a nut to the stud and try to wrench it out. If aluminum block the heat from welding will help. If all fails metal disintegration machining or spark erosion will work, but not cheap.
