I'm wanting to build up a HS50 & have a new short block ( SCH 313C / SER 1074F ) that I think would be a good block for the build.
I'm going to need a donor engine, but I'm not sure what engine to look for.
I looking for external ignition & cast flywheel mod.
Should I be looking for a HSSK-50
I have the ARC ROD, & looking at 245 Dyno cam. Hopeing for pro advice before buying.
Also looking for Hot coil & not sure if still available. Still have a lot to learn & will be doing my homework...
Thanks in advance for any help.
I'm sure I'll need pro help for valves...
but I need a donor engine & clear path first.
