Anyone happen to have a survivor/original HS50 that is on/off or sold through Ruttman that can supply the engine number off it (I don't need the serial number), ultimately looking for the early/right around 1973 version so it would have had a small bolt on tag found on left side of the engine, but I can most likely figure out the standard number from a slightly later one with the numbers stamped on the top of the shroud.
Working on a replication of an early version HS50 with centerfill white tank and just trying to narrow the numbers down to get the correct parts installed and and tag made up.
Thanks for any help :thumbsup:
