this is a good motor. it's had some stuff done to it to convert it from snow to mini (carb and air filter, snow blowers have a weird choke set up and no air cleaner.) You can see it's from a snow blower, it has the carb mounting protection bracket for the snow guard, and it has snow guards around the pull start. It also was an electric start model (you can see where it was mounted.) with some minimal work (needs a mini bike style throttle set up) it could be pushing dirt quite well. it does have a pretty heavy steel flywheel (opposed to say an aluminum flywheel), but that's not a big deal. it's 3/4" shaft too. the gas tank mount is a bit odd, and it's craftsmen orange, but other than that, it's pretty good.
