I call it Death Wish
bmaclean
With the help of member Jim Donovan, I was able to contact Frank Weir to see if he could identify this kart. I got a response back within an hour congratulating me on owning a Bilbrook, built by Bilbrook MFG of New York, NJ.
Apparently the Karts were produced from some time in the late 1950s (earliest ad I have seen is in the December 1959 Quarter Midget and Karting World magazine), through 1965 and manufacturing may have moved to Connecticut at some point. Frank provided the attached ads and from them and a bit more research I am convinced that My Bilbrook is a very early example dating to 1959 or 1960.
If anyone has a copy of December 1959 Quarter Midget and Karting World magazine, I would really like to get a copy of that ad, or any earlier ads for Bilbrook.
The Yellow (then painted silver) cart I posted pictures of above is a later model of the Kart as it has a tube framed seat back and steering column support vs the solid rod squared off design of the early karts.
Note that the cart in the second ad does not have scrub brakes, mine had them added at some point but was originally equipped with a single drum brake. View attachment 312715 View attachment 312716 [/QUO]
cl350rr
Thanks, If I had seen the ad before I started on it I would have built it closer to original but water under the bridge at this point, guess it's a resto-mod
cl350rr
Maiden voyage of the Murder Kart! Powered by a Clinton 501 with a generic Amazon-purchased centrifugal 10 tooth clutch, into an 80 tooth alloy sprocket, that is just a tad smaller in diameter than the 10" tires, I was able to get it up to about 20 mph on the street, rip around my yard, spin the tire and completely wipe out my mushroom crop. I will be smiling the rest of the day and I have work to do on it 1000008210.jpg 1000008211.jpg 1000008212.jpg 1000008213.jpg .
cl350rr
Lessons learned:
The engine produces plenty of torque to get the cart moving and I will be trying out a couple of smaller drive sprockets in the future.
I left the governor on the engine (auger engine) and it is a bit too basic. I will be adding some springs and doing some tuning to get it to respond better.
I installed an oval Tecumseh air cleaner with a paper element (it's what I had), I believe it is a bit too restrictive for the carb.
The drive wheel was not up to full air pressure so I now have some abnormal wear on the outside of the chain :eek:
Although this is not much of a yard-kart, it was great fun in the grass. it picks up anything that is not rooted down and slings it into the foot pan area. also the brake and throttle control linkage points are in perfect positions to pick up all grass clippings :rolleyes:
I was able to reach about 20mph (seat of the pants), which is quite impressive for an 8:1 final reduction low drive tire and untuned carb. I assume I can get it much faster with some more work.
Drum brake is adequate to bring the Kart to a stop in all but the most puckering situations as long as it is not having to fight the engine at the same time.
The dash-mounted kill switch works!
all linkages, steering geometry, bearings, seat, etc. functioned as intended. :)
With only 2" of ground clearance, one must be careful in the route chosen.
Overall a successful first run.
cl350rr
What do you mean open it up? I rebuilt it but have not run it yet. It shares the internals with the D35 I believe.
#31
Maiden voyage of the Murder Kart! Powered by a Clinton 501 with a generic Amazon-purchased centrifugal 10 tooth clutch, into an 80 tooth alloy sprocket, that is just a tad smaller in diameter than the 10" tires, I was able to get it up to about 20 mph on the street, rip around my yard, spin the tire and completely wipe out my mushroom crop. I will be smiling the rest of the day and I have work to do on it View attachment 323908 View attachment 323909 View attachment 323910 View attachment 323911 .
Any idea who makes that exhaust ?
cl350rr
Time to try out a few different final ratios to see if I can gain some ground clearance for my chain
cl350rr
There is a brake drum (slice of 4" pipe) welded to the inside rim of the wheel, to that is welded a 60 tooth steel sprocket. I drilled the 60 tooth to be able to bolt standard split sprockets to the side of it in order to get a better ratio for the small engine.
I started with an 80 tooth (on there now) but the diameter is about 1" smaller than the outer diameter of the tire giving me only about 1/2" clearance between the chain and the ground :eek:. Not a problem on pavement as long as I keep the tire fully inflated but it does a number on weeds in the yard :rolleyes:
