If it is an H50 5hp, then I would have had a frame mounted tank, if its an HS50....well they never came with one so thats added on. The frames and seats are different between the non tank and tanked versions so that is an easy tell to know what model. They did use a band brake on some models but it was on the jackshaft with a drum if it had it. Most the H50/5hp bikes though had a disc brake if it is a scrub brake 6" wheel version, they were normally TC driven originally with the medium frame engines.
