Putting together a Manco Delta 1 chopper that I bought torn apart. Having problems figuring out the brake band mounting and if I have all the necessary parts. Could someone that has one take a pic of how it's mounted. Would really appreciate. Also the spacer tubes on the rear axle bolt seems short. There is a 1/4" gap between the frame and spacer when mounted. Tightening would pull the frame in an 1/8" each side, totaling the 1/4". Is that normal. The tubes are each 1-7/8" long. Is that correct. Don't want to damage the frame. It's 98% together, just need this info to finish.
Thanks.
Thanks.
