While restoring a Mickey bike I needed a sprocket, and decided to share this not in its title or description OldMiniBikes does offer this sprocket in 60T and 72T with a 4 1/2 drum.
The Astro Mickey JDE and Aggie with JDE ( Jim Dugan ) wheel and Trail Horse all have the same bolt pattern
The sprocket is universal and not 100 % with some extra mounting holes but if you need one they are available the spacers that come with it are intended for Astro wheels and are shorter than the Mickey ones, ( I might make some )
The 72T version can be found here
#35 72T 4-1/2" Sprocket Drum for Astro Wheel w/ Hardware AZ2218-IDAS
The 60T can be found here
#35 60T 4-1/2" Sprocket Drum for Astro Wheel w/ Hardware AZ2217-IDAS
Mine is for a Mickey restoration on a JDE wheel so the 60T is correct for me
The sprocket does have some extra mounting holes if using a 4 1/2 internal drum they are covered
For use on a Mickey with a scrub brake they are exposed and this bothered me and looked a bit tacky I thought
So I decided to make a fix to that and came up with this part on my bike
