Most everything to build a new Bad Boy Briggs FH
125ccCrazy
I have a new dual bearing steel bore block, new ARC rod, new valves(exh lightly lapped), new R3 piston set, new Comp spring set, new billet lifters, new alum intake, new mini carb, new copper head gasket, new crank and bearings..
Now the used stuff:
ARC adjustable flywheel, ARC billet side cover, Dyno 107ss cam, front mount gas tank.
To complete the build you'll need , bolts, the tins, a coil and gasket set
$250 plus ship
No trades, I wont piece it out or take less.
Now the used stuff:
$250 plus ship
Hey,
Any idea what the Part#s are for that Carb and Intake Manifold you had pictured above?
