Need Magnetron Part Number Please
I have a 4HP Briggs, Model 100202-0472-01, Code 76041906
I want to convert it to a Magnetron set up. I'm struggling to find the correct part number of the coil that I need.
The engine is the one pictured next to my user name.
Thank you
Thepaetsguy
Thank you
flywheel/coil is different.. 5hp flywheel and coil is a direct swap onto a 4hp engine.
Briggs part # 397358. For that year (1976) the 4HP and 5HP use the same coil and flywheel. This is a direct bolt on to your 4HP engine with no need to swap out the flywheel with a 5HP flywheel as they are identical.
Michael
