@Phil1958 Do you include the Panasonic batteries in that comment about Chinese batteries? I see Panasonic lithium batteries are now (2018) MFGRd in Dalian. I read that dendrite growth and subsequent shorting/fires are endemic to Lithium batteries in general. Thanks for your comment on the subject. Nice to see SME commentary like that.
lithium polymer cells are affected by heat mainly. heat is caused by charging and discharging the cell. the heat causes tiny
lithium particles to move around and line up into little spikes called dendrites the spikes eventually push through the plastic
sheet (polymer) between the positive and negative electrodes. when that happens a short circuits occurs. in old tech cell
overheating and fires resulted. newer cells use special plastics and new shapes to make the shorts "self heal" meaning the
dendrite vaporizes and end up on one side of the polymer. large dendrites can still cause fires! charge your lithiums at 1C
and they will last much longer.
paralleling lithiums if done improperly is also fraught with problems.
