a couple, or so, people asked me where am i going with this surface grinder. this is where it all
started; when i got my mill and figured how to NOT use it i slowly started out how to properly use
it and the tool bits associated with its' use. at first i produced crap on it. nothing was flat, or square,
and the fit and finish was on par with a cub scout den project. even if i made something i had nothing
to compare it to. nothing to verify angles, flatness, dimensions etc. a little while ago i produced this:
it is the epitome of my accomplishments on the mill. my goal was to make it square. using
the metrology i now have it can be proven to be square within .002" over any of its' corners.
the rectangular hole is there because the piece of stock had a drill hole the was in the wrong
spot so i turned a piece of scrap into a useful experiment. before i do any surface grinding
on this piece i will heat treat it as it was purchased annealed.
i have a starrett 13 machinist square that was calibrated against a reference square at the factory.
the square is guaranteed to be square within .0015" over its' length. using a monochromatic 380 nM
blue light source i look for gaps between the machinist square and block of steel. if i cant see blue
light between the square and block the gap is less than .000015". so my basic measurement precision
is the accuracy of my machinist square or .0015" which isn't too bad. i can see some blue
light along the sides so the steel block is not perfect. but for making it on a mill it isn't bad. the error is
an unknown value between 15 micro inches and 1.5 thousands of an inch, most likely closer to
1.5 thousands.
depending on the runout of the surface grinder i should be able to achieve square and flatness
well beyond my current metrology accuracy, which is what i want to do with the steel block.
my metrology consists of a granite surface plate for flatness, a mitutoyo gage block for length, a
spherometer, two reference squares, several good and junk dial indicators, one mitutoyo dial test
indicator. i am also working on a cylindrical square and gage.
this stuff gets out of hand, i actually started ass backwards, i bought the mill first without being
able to measure anything. i had no idea what a surface plate was or why you need gage blocks.
i've done a few small jobs for local people, a cast iron bearing for a case tractor, cast iron piston
rings for an ancient mccullough chain saw, and 50 small mild steel weldlets for a guy repairing a
boat trailer (this was the only job that didn't cost me money!)
ciao~
phil
