Hey guys.
So, I'm working on a 1971 honda trail 70 (CT70KO) and I spent the afternoon cleaning out the carb, the tank and redoing everything I can in the fuel system. I put it all back together and anxiously cranked it. No fire-of course.
I'm not too familiar with points systems, so I'm going to ask for help before I spend money. That's where you come in. I spent a few hours looking at it before finally finding out that it's got a positive body ground configuration. Definitely not something I've worked on before. So I went and found what seems to be an accurate diagram. I've posted it here, if you cant see it well enough the original URL is here: http://ep.yimg.com/ca/I/dratv_2269_123728396
It's got a replacement coil on it, though it has been sitting about 4 years. Here's what I discovered: if you look at the diagram, the coil is fired off the black wire that comes from the ignition switch, and between the two it has a "T" in it that goes to the points and condenser. On my bike that wire shows battery ground all the time the switch is in run position, even when the motor is being turned over slowly. There is a very slight variation in voltage (like, a few tenths of a volt) but for the most part, it's got battery ground on it. If I disconnect the connector that goes to the points/condenser/generator that wire holds steady at battery ground. Again, I'm not familiar with points/condensers, but shouldn't that circuit be switching somehow in order to fire the coil?
How does this system really work, and what voltages should I be expecting to see? My stepdad seems to think the condenser has gone bad, but he's really just winging it. I can't tell you how many times he's just tossed parts and money at something, and that's just not how I operate.
Any tips/tricks/experience you guys could share would really help a lot. Thank you!!
