Delray, the speed run was done for about a little more than 1/2 mile I guess. I use the same stretch of road each time & then duck into the desert at a different gate, to get back on state trust land again. It's a road leading to an airport, out a ways from civilization so there isn't too much traffic ever & I have the pavement to myself usually. Only real problem is the posted 50 mph speed limit, which isn't quite enough at this point. I do ride with a helmet & jacket on this stuff.
Appreciate the tip on wheel bearings. When I took things apart yesterday to change the jackshaft to a lower gear, I noticed the rear axle was a bit loose (nuts were loose on both sides?), so I'm wondering if I have fried bearings, or if I can just repack them. They spin well enough, but I don't know how long the axle was loose since, I've ridden a fair amount at this position on the rear wheel, been over a month I think. The PMR jackshaft is very good for changing gear ratios, fairly quick & easy. I got the "black" spring installed yesterday on the max torque clutch along with the 20t sprocket, so it's time to do more testing on jetting & see how it feels this way. Should be a better pull now with slightly less top end, which is fine with me. Spring's rated at 3000-3100 rpm, which should be much better.
Does anyone know if there are "better" bearings out there for these axles, or is it some bastard metric size which has to come over on a slow boat from China? Might be a good idea to just replace them at some point, if I can find some that are better at high speeds. I haven't had them out ever, so not even sure if they can be repacked or not. Are they automotive bearings, or just the sealed type?
