I have a Briggs 10.5 and hooked up a headlight but it keeps popping bulbs at high RPM. What do I need to do to regulate voltage to the bulb? I don't have a battery and would rather not get one. Do I just need to add a voltage regulator? I just want to keep steady voltage so the headlight doesn't go from dim to popping bulbs with change in RPM. There is just a single red wire from the coil it has around 12v at an idle but goes up to around 20v at full throttle. Any help is appreciated.
