Here's some pictures of started projects. I don't know how many pictures I will post, but I will post more when they're finished. The burgundy one was built from some old tubing I salvaged from a cattle pen gate. Tthe engine plate is made from the fender of an old rototiller. The rear axle mounts are mounting brackets from some type of heavy equipment. Front end from a Huffy low down bicycle. The rear wheel will be a 10 inch with a wider tire. front will be a 60 spoke 20 inch bicycle or bicycle type wheel.:grind::hack::hammer::weld::smile:
The blue one is an azusa frame with mounts added to the rear for a 10 inch wheel. I'll probably go with a wider tire on the back, and a narrower 10 inch on the front.
