I have bent the alum plate a couple times and wondering if anyone else has this problem. I ride my DB30 pretty hard I suppose, because I have also busted the chords on the tires too.
The 1st time I noticed it was bent, I removed it from the engine and straightened it in a vise. The alum plate is fairly soft and easy to straighten, but a lot of trouble to disassemble/ reassemble.
It will bend if the chain is too tight, and tends to bend towards the engine when the chassis flexes (I guess?). The last time the chain was too loose and came off which bent it approx 1/2" to the inside. I have a sprocket protector that works really well keeping a loose chain on the rear sprocket, but the chain will come off if really loose.
This last fix I left the jackshaft on the engine and used a piece of muffler pipe with enough ID to fit over the bearing housing. Then I pried it back into place, using the pipe as a lever. I was pretty proud of the fix, was fast and easy, fixed it perfect.
I love my ProMod jackshaft. I think it is one of the best options for your Baja Doodlebug if you want to keep the 97cc engine. If the jackshaft didn't bend, would probably break something else more expensive or harder to fix. So, OK with me if bends from time to time.
Anyone else have this issue? :shrug:
