I assume this is going to be a race only engine, as your flywheel doesn't have any cooling fins. This type of flywheel can only be run in short bursts as any longer, and your engine would overheat, unless you have a bolt on fan for it. As far as starting goes, it looks like it should work with either of the standard Briggs start setups. There is a pic of the different type crankshafts below. The one with the long snout uses a start/clutch (I didn't have one handy to take a pic of). but I did show a pic of it next to the type of recoil it uses. The crank with the short snout uses a metal cup on the front of the flywheel, and I showed a pic of it sitting next to the type of recoil it uses. Hope this helps.
Matt
