Racing/High Speed scooter
Hey what do you guys think of this scooter design for either a drag racing scooter or maybe a top speed scooter. Its an aluminum frame with a steel front end, so it should be pretty light. 16 inch tires. It sits 1.5 inches off the ground and 60 degree rake so it should be really stable at high speeds. Its designed for a 6.5 hp Honda (modded as much as possible).
ahh autodesk inventor, good waqy to start! sounds like a good idea, id try to modify a cheapy 6.5hp harbor freight engine first to see if the honda will work
Autodesk Inventor i actually got for free because i'm an engineering student at cal poly, san luis obispo. Solid works i can get for 200 days for 15 dollars. Pro Engineer i can get the full version for $150.
ive use a few cad programs. and if you really wanna test your self get a command line cad you dont get to see what your building till you print it
