Hi all,
Have an older H70-130000 Tecumseh engine in a Retek Cheetah.
The engine does run, sorta, but the compression is not where I think it probably should be. Mind you the engine is very old. I found a part number online for a set of 0.010" oversize piston rings and am thinking about installing them. Would that be a horrible idea if I actually didn't get the cylinder bored out?
Also, if I'm going in to replace the piston rings, I figure I'll need a new head gasket. Anything else you can think that I should order? I'll have to pull the connecting rod from the crank, so maybe rod bearings? Head bolts?
Thanks for your help,
-Steve
-Steve
