I have snow kings on 2 of my bikes I'm a happy to report they are very reliable and run well. as far as linkage I just had a hole put the the throttle lever and poked the throttle cable threw it and put a cable stop on the end to hold it. then hooked a spring on the throttle lever and hooked the other end to the plate below it that the grounding wire bolts to. I did this on both bikes and it seems to work quite well. be advised the stock carburator on this engine only opens 3/4 of the way. so your not getting the engines true potential untill you fix that.
