I thought I had purchased an HS50, its was clean, ran good as new, no smoke, and had a 5/8 shaft. My clutch fits right on, but for some reason fills the MTD frame, and hangs out on the right side a long ways. So I looked and its an H60. I cant seem to find the correct 2 stroke Tecumseh, and I think this one probably has more power, but my question is RPM. does anyone know what RPM the original 2 stroke hit full torque, and do I need to adjust the weights to accommodate the lower rpm range of the 4 stroke? I think I may need to change the front sprocket, as this giant rear sprocket may not allow for any top speed. I don't have any clues of the rpm ranges of either, but I am willing to bet the h60 is max torqued at 1800 rpm, while the 2 stroke is likely only hitting the power band at 2500 plus. Any place to find the specs for these engines?
