tecumseh carb help
wile looking for a replacement carb for my hs50 i found one that looks good but the plastic fuel fitting is broke off the carb. there is a metel splined thing still in there. are the plastic fuel inlet fittings replacable??-phil:scooter:
Phil, if your new carb is used........remove float bowl......hold float and shake carb up and down..listen for a rattle.........if no rattle fire that baby in the junk pile.......the idle passage check valve is either varnished or most likely rusted and if rusted....there is no repair
