A year of testing has proven my H50 Billet rod made of 7075 T-6 alloy is a winner! No more worry about cast stock rod breakage with high RPM and modified engines. Direct bolt in, no other modifications req'd. Micro polished bearing surfaces. High strength rod bolts are included.
7075 T-6 description: Aluminum alloy 7075 is one of the highest strength aluminum alloys available. It's strength to weight ratio is excellent, and it is ideally used for highly stressed parts such as aircraft components. Thus it is known as a true "Aircraft Grade" aluminum.
