This was one of my more ambitious projects as I thought it had some potential as a marketable item. Back some years ago (2007) when my son started racing karts in the Yamaha class, we saw the need for some kind of tool caddy/ parts tray that we could use to service the kart in the pits. Time is the enemy in between heats and all too often we found ourselves scrambling for the right tools or crawling on the ground looking for a clip or spring or screw we had misplaced.
Our idea was to design a tool tray that was quick, versatile, and rugged enough to withstand the rigors of everyday use in the pits. We made a few cardboard templates and wooden prototypes before coming up with the design you see here.
It proved itself quite handy while performing all the routine tasks; sprocket schanges, clutch service, carb adjustments, caster/camber/toe setting, wheel spacing, tire changes, etc etc… You can even run the engine with the tray in place. I guess if it had one one drawback it was you had to pull it off to read or change the plug but for that we would just move the tray to the seat .
Heck we even came up with a pretty clever name for it, playing off the KT100 Model name.
