Revisions dated as late as July 1974 still show the small frame H and HS40 using the round top shroud and thinner aluminum flywheels, unfortunately I don't have a revision after that showing the start up date for the conversion to the larger steel wheels and bigger shrouds but some other advance revision sheets I have show major changes that happen around October 1 dates..getting them in full swing for the new model year. I do know that the HS40 went "square" by 1975 only because I have had them off Late roadster2's. Sometime during 1976 (still trying to get a better timeline on that) the heads changed to reroute the plug wire straight up from under the shroud instead of wrapping around the front and they angled one of the fins to clear wire. I have never seen a mini bike specific have the wire routed from the back, I did get a snowblower engine in once that did appear to maybe have been original like that, but it was pinched to the point of going through the casing up against the corner of the breather or something. it may have been re routed to clear an optional 120v starter, which is most likely the reason they simplified and went to the plug thru the top setup on the entire small frame lineup.
