I'm going to get one of these Tec. engines.I wanted to throw them up on here to see if there is anything I should be aware of with any one of these engines.I will be using 1 for upgrading my 5hp Tec. engine in my mini.I have plenty of room in my frame.I will also use my Comet TAV2 on the engine.I have read the Comet TC can be put on engines up to 8hp but I have seen them on several 10hp Tec.engines online.I'd appreciate anything you have to add.
1.Far Left Engine Is:
10hp Horizontal 3/4"x2-3/8" Shaft, Muffler, LOS, 1 Gallon Tank, Recoil Start, Adjustable Throttle
Product Number: LH358XA-34-Adj
10hp Tecumseh
Cast Iron Cylinder Sleeve
Mounting: Horizontal
Electric Start: No
Fuel Tank: 1 gallon
Oil Capacity: 26 ounces
Oil Type: Summer: SAE 30, Winter: SAE 5W30
Shaft Size: 3/4"Dx2-3/8"L
Muffler: Included
Height: 13.7"
Depth (Less Shaft): 12.4"
Width: 17.9"
2.Middle Engine Is:
TECUMSEH 8 HP
MODEL: HM80-155661 POWERSPORT
POWER SPORT GO Kart Engine or Minibike Engine
These engines have been stored in a warehouse for several years. The shaft may show oxidation signs from just sitting for so long and you may need to be lightly sanded. They are new engines bought from Tecumseh by a kart manufacturer that just never used them and left them sitting.
# Enduro Power Sport series
# Recoil starter
# 1" Diameter x 2-9/16" Keyed Crankshaft
# Spring loaded remote throttle
# Has Fuel Pump
# Drilled and tapped mounting pads
3.Right Engine Is:
Tecumseh HM80 -155726 (Z) 8 HP
New Model Number: LH318XA - 156033
For Troy-Bilt Tillers without 2:1 PTO
# Recoil Start
# Cast Iron Cylinder Sleeve
# 3/4" x 2-3/8" Crankshaft part #36245
# 3/16" Keyway - Drilled & Tapped 3/8-24
# For a Troy Bilt Tiller Without 2:1 Aux. PTO
# Has muffler guard
# Ideal for tillers -
# This small engine fits many Troy Built Tillers
10hp Tecumseh
Electric Start: No
Fuel Tank: 1 gallon
Muffler: Included
Height: 13.7"
Width: 17.9"
2.Middle Engine Is:
TECUMSEH 8 HP
# Recoil starter
# Has Fuel Pump
3.Right Engine Is:
# Recoil Start
# Has muffler guard
