it's a diaphram carb. the way it works is the diaphram works off of vacuum from the engine. kind of like a fuel pump. this way you don't have to use a bowl carb. another advantage with this carb it will run at any angle. it should work if it has adjustable fuel and idle mixture screws and a choke:thumbsup:...............
