Worn clutch key help.
The fix/built in key on my new to me comet clutch is almost gone.
The prior owner had drill a small hole on the engine shaft so to get the only set screw to sort of lock the clutch to the shaft.
I am contemplating drilling a couple holes right above the shaft key way and install two more set screws.
The clutch still has meat to wear. Any other ideas are welcome.
PS. I also tought of drilling right trough the clutch and shaft and install a bolt O.O.
Jaime
I will get a new clutch in the near future Pap. I will keep an eye on it.
I still have a lot of things to workout on this OldMiniBikes Neo71665. Once I work all the bugs out I will replace the worn parts with new ones.
Plus there is fun trying to figure a fix or temporary patch to something that is almost gone.
Thanks for the comments.
Jaime
