Well, the engine is basically finished. This is my 6.5 by Minidragbike.
The build is as follows:
Champion 6.5 OHV block .010 over decked and align bored
Honda OEM head ported by MDB with 2 angle valve job
Honda OEM crankshaft
Isky 310 special order cam
Ibea swiss made billet carburetor 1" bore
ARC long rod, flywheel, and top plate
Honda piston and rings
Champion shaft mount lifters (stock ratio).
Stock pull start and shroud
While I finish the Sears, I will put this engine in another frame for some fun at the drag races. who knows, it might end up staying there. As you can see, this engine has parts made in at least 4 different countries and three continents, so I can tell myself it's not really a Chinese clone.
