you need a rear wheel on the front, rotor, caliper and lever. Make a custom bracket and weld it to the forks. You have to machine :hack: the flange off the sprocket side of the rear wheel and make a couple spacers.
2 weeks ago I finally hooked one up on my red DB-30, it works great. I made new fender mounts also. I have to paint it and it will be done.
Thanks for the pics! My buddy and I are checking it out now. We have come to the conclusion that until we get better brakes, there isnt much sense in increasing top speed.
the front brake works great, the mini stops on a dime. you have to keep the steering head bolt tight so you don't get any slop in the forks. I bought the wheel and brake handle from Baja Motorsports. The caliper and rotor I got from ebay
My dad says that before I get a bigger engine, I have to make my bakes better. My brakes are bad now, so I might be able to get him to help me put on some front brakes, if he agrees.
you should make this your next Kit and sell them ! a lot of us dont have the required welding skills or the tools to even try... you could buy all the parts, weld them up and ship them out ! these bikes sure need the extra stopping power !
It would be tough to sell as a kit because the caliper bracket is welded to the forks. I wish I could help DB owners with a front brake set up but the cost of the parts (to buy them new from Baja Motorsports) welding the bracket to the forks and machining the hub on the wheel would be expensive.
