I guess I am thinking backwards but I was thinking the big one way gear would be a top speed but as it is supposed to work, the 13 tooth or whatever secondary clutch is a higher gear ratio compared to the 18-20 or whatever the one way gear is.
takes off with the one way larger gear and then as rpm's increase it slings the jackshaft clutch/smaller gear into play which spins the jackshaft fast enough to make the one way gear freewheel. correct?
edit, after looking at the clutch picture, both gears are locked together and engage with the clutch, still confused as how the jackshaft works then.
