Massacre,
The tooling and support equipment alone would very expensive, all structural carbon fiber is what is referred to as pre-preg laminates which require heat ( 150 to 350 F ) and vacuum along with high pressure ie autoclave, with that said other components could be made with wet lay-ups ie resin and fabric cured under vacuum to make seat pans, fenders, levers, engine covers. I hope this helps you have an idea of how the process works and I didn't get to technical. If you want more detail pm me and I will be glad to answer more questions.
Thanks for asking.
Tim
