Briggs 5hp, pull choke carb, 3/4 diameter 1 1/4 length shaft.
Sitting on the shelf in the shed for 15 years, good compression N' Spark.
$65 local pickup, $90 shipped, $100 shipped west of the Missippi.
If you are looking for a new engine i have what you need.
I have an open that does 90 mph, most run on methanol but others run on gas, i am an expert engine builder and used to race the wka gold cup karting series.
If you are interested in your bike going really fast or upgrading your...
Gentlemen,
For sale is my 1982 Briggs and Stratton 5HP engine. This engine has new Briggs OEM chrome rings. The carb has new gaskets, diaphragm and was cleaned in an ultrasonic machine. The valves were cleaned and lapped and lashed to B&S specs. The engine runs and idles well and does not...
Here is my entry for the 2012 OldMiniBikes Vintage Class Build Off. I will be using a Bonanza 1300 frame with a 5HP Briggs engine. This will not be a full restoration but not nearly all custom either. The heart of this build will be with the engine. The 5HP Briggs will be built for as much power and RPM...
i had a 5hp briggs that ran like a sewing machine. i took it apart to replace the crankshaft. as i was trying to crank it over to get it to run, it siezed up on me. upon further inspection i found that i scoured the cylinder. this is a 1995 5hp Briggs and Stratton with a flowjet carb. all the...
Hey all,
Looking for a comet or equivelent, 3/4" driver for a MTD trailflite. Bike came originally with a Fairbanks - Morse unit, and currently has a cheap Comet knockoff that doesn't engage properly.
I am also looking for a manifold to adapt a Mikuni 22 to a 5hp Briggs flathead. If able...
Why would a 5hp birggs have a 1" shaft on it? Im putting it on my mini bike and i know the clutch is going to cost around $100. But im just wondering why. Thanks for any replies.
