engine help
  1. Heidle
    Coleman CT200U rough idle/weird low RPMs
    Hey guys, I recently rebuilt my Hisun 196cc motor and when I run the engine it idles roughly. Here's some specs 18 LB valve springs PVL Aluminum flywheel with 31 degrees BTDC Billet con rod governor removal BSP-2 cam Everything else stock The engine seems to run fine at higher RPM but at idle...
