What kind of flow numbers are others seeing on their heads? I've been playing with 27mm intake valves recently and the last couple heads I've been topping out in the mid 70's for the CFM. Here's the flow data for the last head I did. Anybody have any tips to share or have I pretty much reached...
Red carb was on a 5hp green was on a 3hp. Engine ran with red one green one I bought and never used.
$35 shipped for both and extra parts.
Gas tank was on a 3hp Briggs. Super clean inside
$25 shipped
Hello All,
Does anyone know where I can pick up a stock bore size piston for an old AH51?
These were the cross flow scavenged engines requiring the deflector topped piston.
Thanks in advance
Mark
The engine wont run off choke. Cleaned the carb tried putting the muffler back on for less air flow. Could Ive damaged the black spacer some how thanks.
hello everyone, I was wondering if anybody had any flow charts for a Honda gx160 cylinder head? either home ported or stock.
I couldn't find anything, I need this for a cam grind reference
I have the ability to flow heads and carbs now, with actual CFM numbers. What are some of the highest numbers you guys have seen with modified heads? I am flowing at 28inches, by the way. I found some stock flow numbers on here the other day, and my stock numbers were right with them.
Could just changing from the stock filter to a cone style filter cause my predator engine to take several pulls to start? Maybe I need a bigger emulsion tube /jet?
This exhaust pipe has a drilled out muffler and is smoothed on the inside of the bolt on end,its been bead blasted and painted with VHT high temperature paint.it is quieter than an open header but is still high flow.
$25 plus shipping.
..This is a small SUPERFLOW flow bench,110v table top model.The machine is in Orange County,CA. and the price is $770 Cash,no trades please.
Here is the like to my ad,thank you,Don
SUPERFLOW Flow Bench
Anybody use trick flow heads before? There is a small block motor im looking at to buy and it has trick flow heads! Ive never had trick flow anything before but I know people who have trick flow headers and they not the best! :hammer:
So what is the quality of trick flow heads and are they...
Tried to fire up my rupp last night and realized I was getting almost no gas flow from my new gas tank..I thought it must be plugged up but after removing the petcock I realized it is just the design of this thing..It has a very tiny hole to let out the gas..Anyone else run into this?..Here is...
