Hi All
I just tuned up a briggs carb 3.5 and it will not start and run without fluid. I'm not good with Briggs. It idles, runs and throttles up fine until it is shut off then wont restart without fluid. What am i missing?
Thanks
Xander
I have a two speed transmission that is 90 weight oil filled that even with new seals, leaks around the seals. The shafts are not the problem. The movement of the shafts side to side cause the oil to weep out. The shafts have to move in order to change gears.
I've seen there are fluids you can...
OK so with some searching around I'm finding different answers, what type of oil is recommended for a Kawasaki MT 1 I picked up this summer. I forgot to ask the PO and I saw that Gatecrasher here has posted some good stuff but his link is now dead.
10W30 engine oil?, Bel ray? Honda GN4...
Does anyone know where I can find some info on where the transmission fluid goes or how to check/replace it? I found a 60s-70s model (I think) Coleman 2.4 mini bike with the Sachs Saxonette 47cc 2 speed automatic in my grandmothers garage and got it running again but I'm having a few problems...
Just bought a used bike. Can I get a service manual or at least a wiring diagram? Also. there is a plug on top of the clutch housing. Is that supposed to be filled with fluid.
Hi, my HRMB hydraulic caliper failed today. It looks like I can get away with just a new caliper which includes new brake pads for $27+s/h.
To replace the caliper.. I'm guessing i just need to unscrew the gold bolt going from the brake line to the caliper... then fill with new fluid and...
Hey yall, new to this Forum. I am restoring an old Sherpa bike that has the two speed transmission and was wondering if anyone could tell me what kind of fluid I should put in it? The transmission that is
71 Rupp Roadster 2 4hp lighted Tecumseh engine. Good comp. excellent spark!
Pops off of starting fluid. Needs to be cleaned and tuned.
Listed here first.
230.00+40.00 to ship
Calling all Saxonette owners.
I was changing the transmission fluid in one of my Sachs engines the other day and noticed a metallic swirl. This is from a 47cc Saxonette on an Arctic Cat. I've been around these engines since the late 70's, with a 30 year break in between, but have never gotten...
Hiawatha Doodlebug style fanbelt clutch. (1946-1948)
Belt drive clutch with the letters AMX stamped into the outside face.
1/2" bore for the old cast iron engines.
Appears to be in good condition.
PM me if interested
$300.00 Delivered
can anyone post a pic of where the trans fluid goes in and where to check it at? and where to drain it? its a sax 47cc. also which chain size goes on the bike?
i tried #40 but is too wide? #41 the right size? also two wires comming out of the bottom of the engine, one red, one black. the red...
