Here is how I relocated my tank to fit in a Cat frame.
I used a piece of 1.5" x 1.5" aluminum angle stock about 7" long.
After measuring I figured a 2" offset would do.
I used these mounting holes.
Next I mounted the bracket and tank using some rubber washers for vibration.
I may...
Just thought I'd post a few pics of my ongoing mini bike project.
Decided to relocate the real gas tank above and still use the fake tank as trim for the real tank.
Also did a bit of painting, removed muffler and added a straight pipe, Added a rear swing arm with rear shocks...
Before...
need advice on how i can lower the fuel tank on a tec h50. any one make a lower mounting bracket? will this effect fuel flow if lowered, motor will not fit in my frame with out do this. thanks
