well that stinks. im trying to stick a bigger motor into an azusa frame and the clutch is just too far out for the chain. if i push the engine back to where it aligns its sticking way too far out the right side of the bike. i guess i have to use a smaller motor for this frame.
What engine is it? Can you swap in a 3/4" crank? You can have the 1" crank turned down to 3/4" and have a new key way cut
if it is special engine... Not sure what that would cost though.
not sure what running it inboard means.. its a 10t sprocket from an azusa frame. i just wanted this build to be cheap and easy... looks like that won't be the case. lol
