I am thinking about how im going about my Manco Quester project and i have several 1 inch shaft engines i could use that are big enough for the power i am looking for, but 1 inch TAVs and clutches are expensive and none of them have lighting systems or charging coils.
while considering a way to solve these issues i came up with something that would cover both, and im looking for input
I thought about running a small honda car alternator for 12v power, and a very small battery for voltage stabilization. then i wondered if i needed to run it off the engine or if i could run it off the jackshaft, and how much HP loss i would see
then i thought well i could run a 1:1 gear chain setup from 1 inch shaft to a 3/4 jackshaft that has a 3/4 TAV driver on it, as well as an alternator pulley.
looking for any info, comments suggestions anything im open.
i think i can get away with using a car alternator if the engine is up to it because ive got lots of room in the rear under the fenders to work with. obviously this wouldnt be feasible for most mini bikes but im getting tired of no options for lighting
has anyone found a small engine 12v generator yet?
