Tracey's top notch fabrication skills are clearly showcased on this creation. Apparently built as a result of a dare by friends, the chassis is constructed from 4130 tubing. Power comes from a Honda 160cc single cylinder engine fitted with an IHI turbocharger. A ceramic coated, 2 inch exhaust dumps the fumes. A custom, billet, belt driven, oil pump was fabricated using Cummins fuel pump gears and Bosch relief valve parts. The fuel tank was hand fabbed from .080 aluminum. Braking is by a Hurst/Airheart hydraulic kart setup with cross drilled rotor.
