195? Jacobson
Video isn't working. Did it work out for you.
It seems to run great , the next step is to make a shaft adaptor for the clutch , its an odd size 11/16 diam and stubby
The belt v belt clutch I picked up is 1" so the lathe work will be fairly easy
The other hurdle is to make a 90 degree manifold for a small mikuni carb (z50 or similar) so the engine can run in the upright position
My original plan was to convert it to reverse rotation to match the original jackshaft but I am going to flip the swing arm and swap ends on the jackshaft
More pictures as the story unfolds
It runs great! Also, if someone gives you any hassle while riding, you can knock them out with the pull start rope weapon. :thumbsup:
