Listing for a friend. I sold him the frame .He is one of Detroit's street racers also. This one has a lot of good work done on it. This one is a semi Custom. Mint frame powder coated in Silver metallic. All new custom built Predator engine. Flat top piston. It has a Honda 65th milled head.Some port work.21 mm Stainless valves.265 Dyno Cam 26 lb. springs. Good retainers. Adjustable 1.0 rockers, Billet rod and flywheel. Hipo crank bearings. Billet lifters. Billet intake. 22mm Mikuni. Walbro fuel pump. Hilliard clutch. Custom Seat. All new never raced. It is dialed in. 66 Tooth Sprocket. 5:30x4:50x6 tires. Custom aluminum tank. Kill switch. All new handle bars etc. There is around a $1,000 in the engine and driveline alone. He has around $2,200. into it. He would take $1,150 . Should do 60 Mph. @ 8,000 rpm. With 180-200 pd rider.
