Its a four stroke engine no mixing of oil to gas,Check the crankcase for oil, Better yet!, Change it, And put 21 oz. of 30 SAE oil back in to it, in the rear oil plug on the engine. It has been sitting as long as it did the gas in the tank is probably bad and evaporated out of it over time. How clean is the inside of the tank. You may need to clean it up, Check the screen on the petcock and or replace the petcock if necessary. Also those carbs. like that can be a real pain when they have set for a long time, so it may not be working properly.Brandt with Ruppparts.com has a lot of Tecumseh engine parts he also sells on ebay. The spark plug should be a J8C champion, If I remember correctly.
