Not sure about the X90 specifically, but the light switch contact will probably also make in conjunction with the ignition switch contact (lights on when engine on). Also, not sure if the switch grounds to the body of the switch, or one of the contacts would be ground. You’ll have to continuity test various switch and contact positions to see what changes as you turn the key.
