I recently picked up this little 2 stroke Kohler engine for a future project.
There is really no good way to mount the clutch on the crankshaft on this motor, so I'm going to weld a sprocket onto a matching crankshaft plate and bolt it on. The clutch will be on the jackshaft.
Now the gearing is where I'm a little lost. :shrug:
I know that "usually" when mounting a clutch on the jackshaft, you want the same 1:1 ratio with the sprocket on the crankshaft.
But because this is a 2 stroke, it won't have low end torque like most engines.
So would it benefit me to use a 9 or 10 tooth sprocket on the crankshaft and a bigger 11 tooth on the jackshaft clutch? That way the clutch won't engage right off idle and until the revs are a little higher. I don't know how to figure the math on something like this?
I think the smallest sprocket available on most max-torque clutches are 11t. I know there are more expensive racing clutches that have some adjustability on when it engages, but I'm trying to keep this next project affordable.
Any thoughts or input appreciated! :thumbsup:
