3.5 tecumseh paint
Honda passport. 101W. Is the code. This what I have been using all the time.Bill base coat clear coat works the best because the base color is thin and don't fill in the numbers on motor stamping. Aluminum tags or shrouds . the clear is hardened so it with stands the gas and oil and holds up to the heat pretty good. My VT7 I painted about 5 years ago is just now showing some age on it as the color is getting darker. Acid etch the whole thing too about an hour before you paint color on it this helps the adhesion too
